re -using set outputs again
mtixente
Aug 2012
durban
22
hi folks, my practise is like this; i have three LED that flashes three times at the same time, then all comes off. after 2 seconds LED one should come ON for 2 seconds, then OFF, comes LED TWO for 2 seconds again,OFF then LED.....
I used set and reset on my program, my question is how to re-use set/ reset on ZELIO Soft?
file attached!
thanks in advance
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,088
Hi, I have this code: LAR1 P##structy L 0 T LW [AR1,P#0.0] which resets all the bits in this struct called structy...
643
Dear All, Currently I'm working for PICO Hydro system that installed at remote rural area which there have no power supply from service...
1,476
Hello friends. I am working on a project that needs the time to be somewhat accurate for their process. I have taken time for granted and really...
6,451
I have problem to set wallclock for controllogix by using SSV.
2,811
