reactive power calibration to HMI
rj061991
May 2014
iligan city
75
hi.. i have a reactive power meter..i would like to visible in my HMI.the hmi has built in analog input module..that allow different input signals.the reactive power meter ranges from -100 to 100 mVar.. using 0 to 20mA.. 0mA in -100 and 20mA in 100... is it correct?? because someone told me that i should used -20 to 0 mA in range -100 to 0.. and 0 to 20mA in 0 to 100....
my idea is only 0 to 20mA,, -100 to 100...
THanks
If the output is a normal 4-20mA output, 4ma would probably indicate -100, 12ma would indicate 0, and 20 would indicate +100.
As always, check the actual manual. I don't have it in front of me.
Hello all, I have some doubts regarding the sizing of the protection and cables for a reactive compensation. The reactive I have to compense is...
1,005
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
39
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
299
Looking at installing point io, with a 1734-AENTR communications adapter and ten 1734-IT2L modules. In IAB it installs a 1734-EP24DC after every...
76
First time I've used either the software or this unit. This is the setup I have right now. I have 20mA coming into AnalogIP1. Both the Main.PV...
49
