Read/write BOOL data between Logix PLCs
Sam_R
May 2021
Illinois
Greetings.
I have a 1769-L30ER that runs a new piece of equipment my company bought. I would like to read from and write to some tags on this PLC with a 1756-L82E. I can use a series of MSG instructions to read and write all the REAL and DINT values that I need, but I can't find a good solution for the BOOL data that I need because the MSG instruction doesn't support BOOL data.
Normally I would set up a produce/consume tag structure between two PLCs, but the program on this new equipment is locked and I can't view or edit any existing code.
I thought at first that I would create my own program on this PLC and then pack up all the BOOLs into DINTs for transfer, but most of the BOOLs that I need to see are program-level tags. I can't edit the programs that these tags belong to.
Am I missing an obvious solution, or am I just S.O.L.?
I'm not aware of any way to access program-scoped tags from within another program.
Any chance there's a Red Lion HMI on the machine? If so, and if you can edit its program, it's easy to add gateway blocks to transfer data between PLCs.
Is there a way to copy a program-level tag's value without being able to access the logic in that program?
Public parameter.
Whether intentional or not, a Program-scoped BOOL tag that is in a program you cannot edit is fairly immune to PLC-initiated messaging (onboard or in ar emote PLC) and program logic.
I agree that an HMI or other software that has access to those Program-scope tags might be the best thing to act as a data broker.
If your OEM set up the Program-scope logic to be inaccessible on purpose, they might have also disallowed external access.
Dear all, glad to be here and I hope that we all can benefit from this great community. I am trying to send and receive data between two Mico850...
2,759
Hi everyone, I am working on a project that needs to expose the SV (Set Value) of a temperature controller to a SCADA system. SCADA <-...
161
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
129
Dear colleagues, I am reaching out for assistance with an issue I am having. I have a code that can successfully insert data from FactoryTalk...
1,053
