read-write thru dh 485
labingtone
Aug 2002
Manila, Philippines
113
hi to all,
we have existing slc 5/03 in our plant and we are going to add 3 more slc 5/02. Each slc 5/02 has dedicated AIC 1747.
We are going to make the SLC 5/03 as initiator and the other 3 SLC 5/02 as responder on a DH 485 network.
The SLC 5/03 will communicate with a DCS(master) thru a MCM 3150 as slave.
My 3 slc 5/02 will send data to slc 5/03, the slc 5/03 will then pass this data thru MCM 3150.
Please give me some guidance to perform the programming to accomplish this project.
many thanks,
Lovington Dela Cruz
The easiest way is to have an AIC+ on the operator interface and the master as well as the slaves. Use the RSLogix message block to initiate communications to the slaves. It helps to have your data in contiguous blocks so the number of transactions is minimized. Double clicking on the message block brings up a setup screen that is fairly straight forward. It includes addressing info, with separate data block start and stop for the master and a destination block for ht slave.
Hi everyone, I am working on a project that needs to expose the SV (Set Value) of a temperature controller to a SCADA system. SCADA <-...
175
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
145
Dear colleagues, I am reaching out for assistance with an issue I am having. I have a code that can successfully insert data from FactoryTalk...
1,070
Does anyone have example code of how to read/write a discrete push button from a C-More Micro to a DL05. I just bought these two items and I am...
995
Greetings. I have a 1769-L30ER that runs a new piece of equipment my company bought. I would like to read from and write to some tags on this PLC...
1,445
