reading array variable
smsebnaa
Nov 2014
tehran
32
hi everyone
i have siemens cpu 1214 FW 4.1.
i want to use fieldRead for reading 50 USint array variables.
if i use 2Hz to enable fieldRead this is ok, but when i use 10Hz , fieldread can not read all of my variable carefully!!!
my questions are:
1. this is reasonable that filedread read 50 array at 1 second?
2. what is the max speed of fieldRead?
After learning here how to create arrays in RSLogix5000 ver 20.04, I have added some monitoring for a HMI to show 1 of 3 conditions for a bank of...
2,051
Hi: I am trying to read an array of 100 elements from ControlLogix to FTView SE, using VBA. I need to asign all the elements to another array tag...
2,600
I have a tag called 'MBTCP.DATA.ReadData' INT[600] of which I would like to pull 16 sequential values into an add-on instruction. I will need...
2,534
Looking for the easiest way to read an array of values from a controllogix processor into a PC. This 200 element array contains the instantaneous...
1,661
Just sharing an experience with a weird one that had 3 EE's scratching our heads for a bit... A PLC5 program was converted to CLX, version 20 in...
11,194
