Add on Instruction reading parts of an array RSLogix5000
tomthelampy
Feb 2017
Bath
I have a tag called 'MBTCP.DATA.ReadData' INT[600] of which I would like to pull 16 sequential values into an add-on instruction.
I will need to do this a lot so rather than input each tag identifier individually I was hoping there was a way that I can reference 'MBTCP.DATA.ReadData' then the starting number [70] for example and read all 16 values.
Is this possible?
Thanks in advance.
Tom.
Yes, you can pass the entire array as a reference and your starting number as a direct input. Your aoi will use that information to read the 16 values you are looking for.
In the AOI i have a parameter "Reference" with the type "INT"
When I try and use 'MBTCP.DATA.ReadData' as the input it gives me "??" as the value and gives an error "Missing reference to array element"
Apologies if I've misunderstood, am I going about this wrong?
When I try that, a pop up says
"Failed to set tag data type.
Invalid array. Input or output parameter must be BOOL, SINT, INT, DINT or REAL with no dimensions."
I had the usage set in Input rather than In/Out. Looks to be working now. Thanks for your assistance, and for reference I'm on V28.
Thanks again!
hey good afternoon ! I have a simple question, I need to import an Add on instruction to a controller that is in operation and cannot stop. Is it...
298
please can someone help me how do i add status bits to the add on instruction in studio 5000 thank you
1,476
Hello all, Is there a way to trend tags associated with AOI? Currently the selection is grayed out. The tag is a local tag and it resides in a...
2,129
I have to create a sample mov template in add on instruction.I just want to know the list of tags which is used to create a mov logic instruction...
2,092
I know this sounds really stupid, but I have a function block program I have written and have been debugging. I have an ADD block that will not...
2,358
