Trending Add On Instruction Tags
nik124
Jul 2018
Cali
40
Hello all,
Is there a way to trend tags associated with AOI? Currently the selection is grayed out. The tag is a local tag and it resides in a specific program scope. There is no alias for this tag either. Other tags that reside in this specific AOI show up as a selection to trend and some do not in the same AOI. Any help is appreciated!
Interesting.
When you create local tags in an AOI, their "external access" is None by default. I was thinking that this had something to do with it. Turns out not to be the case.
This appears to be some odd limitation of the trend as I can access local AOI tags outside of LogixDesigner (when set to read/write or read only access), so it seems like there should be no reason that the trend couldn't have access to them.
Can I create a tag to alias to that tag in the AOI or is that not possible?
Nope. I think you are going to have to edit the AOI. If you look at the tag instance of your AOI in controller tags, you'll see that the local tags are not accessible.
Hello All, I am having a problem with some of my trends. I am using Historian tags in my trends. I have 2 clients that look at the exact same...
860
Wondering if someone has a good solution for Datalogging and Trending. Don't have any specific HMI needs, so could run it on a PC or a VM. So if...
20
4,086
This isn't a question but more like a FYI. I was using a bunch of trends (around 15) each fully loaded at 8 pens each. Over the course of a few...
921
This forum post I found seemed to reference the same issue, and if posts were still allowed on that thread, I might make an account there to post...
5,793
Ladies and Gents, I have never used this program and got thrown into it due to our main guy moving to another project. Anyway, I hope it's easy...
1,354
