add on instruction studio 5000
First is this an AOI that you created it.
you can not unless you have editing rights then you can't
if you can edit it then is an output paementer
we realy need more informatio to get into deails
Just to add to Garry's post, configured as an output only means (well according to the IEC convention) that "IF" (note I said if), you also try to use it effectively as an input internally i.e. return back to the function the last value it output, then it should be configured as an IN/OUT parameter. the reason for this is that input parameters are passed to local variables within the AOI (FB) but the outputs are not so the data may have been destroyed, I do know that some platforms do retain the information due to the way the internal variables are used but cannot be relied on, also if it complies to the IEC standard a parameter that is OUT only will cause a compile error if it is used as an in parameter.
Hello, I have an add on instruction block that a coworker created and that I am adding onto. I basically added a few parameters. The original...
2,433
hey good afternoon ! I have a simple question, I need to import an Add on instruction to a controller that is in operation and cannot stop. Is it...
298
Hello all, Is there a way to trend tags associated with AOI? Currently the selection is grayed out. The tag is a local tag and it resides in a...
2,129
I have to create a sample mov template in add on instruction.I just want to know the list of tags which is used to create a mov logic instruction...
2,092
I know this sounds really stupid, but I have a function block program I have written and have been debugging. I have an ADD block that will not...
2,358
