Reading barcodes with Sybmol scanner WinCC Flex
smakdown61
Aug 2009
NC
90
I'm trying to read barcodes using a symbol scanner that's attached to my mp 377 (win ce) panel via usb. I have the scanner set to emulate keyboard mode, but when I click on the i/o field and scan, it just deletes what was in there and inputs nothing. I checked the length of my tags and they all match and are sufficient for the bar code I'm reading. Is there a special script that is supposed to run to get this scanner to read in?
When scanning a barcode is it possible to read a number of characters out of the code. How can I read in, say the first five characters only...
1,899
173
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
113
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
96
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
249
