Reading Ext.Data Registers in Mitsubishi PLCs
Hemanthapte
Mar 2014
Bangalore
Hello,
Will the Protocol format 1 or 4 support reading of ER (extended data registers) in Mitsubishi PLCs?
Which protocol i have to implement to read/write to ER device type of Mitsubishi PLCs?
I could not get this information in any websites. :oops:
Thanks in advance.
with regards,
Hemanth.
Hello All,
I could get the answer myself by reading Q series PLC manuals.:D ER stands for Extended File Registers. It can be supported by Mitsubishi format 1 or 4 protocol.
Still to implement it with many device address ranges. o_O
with regards,
Hemanth.
Hello All,
I am still facing problems reading Extended file registers using protocol format 4. This protocol do not have any command for reading ER device types in FX-3U OR FX-3G PLCs. How do I read ER using protocol format 4? OR do I need to implemented different protocol?
thanks in advance.
with regards,
Hemanth.
Hello. I have a problem which may be common in this part of the world. My CoDeSys program reads data from a text file that I generate from the...
2,456
Maybe stupid question, but.. :huh: I need to read external status from Danfoss vlt, which is connected to S7/300 via profibus. I have done my...
1,201
This is my first post and I think this is a great website. I am currently trying to read a .txt file from a remote computer on the network, into...
5,672
173
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
113
