reading Ext. status indirectly from VLT
Nepiter
Apr 2010
At job
79
Maybe stupid question, but.. :confused:
I need to read external status from Danfoss vlt, which is connected to S7/300 via profibus.
I have done my own VLT controll FB.
Area of reading is determined by giving VLT address at FB input field.
With two first row, I can read actual reference and status from double word (example PED256).
But I need to read also word PEW 260, indirectly.
How should I call that word at FB?
L PED [#address]
T #From_VLT
L #From_VLT
T #Status_value
L #From_VLT
SRD 16
T #Status_word
L #Status_word
L 2#110000011011000
UW
L L#0
>I
= #VLT_fault
..Not enough coffee in My blood..
I quess there's some fancy way to do this with pointer or something,
but I think this will solve my problem:
L #address //peripherial address 256
+I
SLD 3
T #pew_3_tmp
L PED [#pew_3_tmp]
T #Ext_w
This way I managed to read ext.status word from VLT address 256.
Hello. I have a problem which may be common in this part of the world. My CoDeSys program reads data from a text file that I generate from the...
2,454
Hello, Will the Protocol format 1 or 4 support reading of ER (extended data registers) in Mitsubishi PLCs? Which protocol i have to implement to...
1,587
This is my first post and I think this is a great website. I am currently trying to read a .txt file from a remote computer on the network, into...
5,668
167
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
111
