reading from a CF during Powerup
sunnyvaleplc
Sep 2009
sunnyvale
Hello everyone,
I am reading and writing to a compact flash in the compactlogix L32E controller. I wanted to know, how can I read from the compact flash JUST ONCE during the Power up only.
I need this, to re-instate the tag values that were changed before power cycle.
I have tried the S:FS and the power-up handler and both doesn't seem to work. I can read from the CF during normal operation, so I know the reading part is definetly working.
How do I just read only once after a power cycle ?
Thanks,
sunnyvaleplc
I'm guessing that the PLC isn't quite ready to read from the CF card when you are trying to.
Latch a bit on the first scan of the processor. Don't allow normal read/write access any time the bit is set. Perform a separate read to determine only if any reads are successful (I assume that an unsuccessful read will throw an error). Once you get a successful read, trigger the restore read from the CF card. When that read completes, reset the latched bit and allow normal reads and writes to continue.
Keith
Hi, I've been wondering when DB an M areas of S7 PLC are read during scan loop. I want to block some of the events coming from WinCC ( DB -> M )...
2,201
163
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
110
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
88
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
237
