Reading String over Modbus
FNC
May 2010
NJ
84
How does one go about reading a string over modbus?
I can convert the string to 16 bit integers without a problem. How does the Modbus client know how many 16 bit integers are in the string?
Is there a default value?
Ok that solved it. I think my Modbus issues are resolved as of now.
Thanks for everyone who responded to my various Modbus questions!
I am trying to read a string from a remote compact logix to another compact logix. I have the msg instruction is setup but it keeps coming up in...
2,651
I recently converted a PLC-5 program to Controllogix and using iFix as the graphic interface. I seem to have trouble reading a string and...
3,723
I have an existing Ifix PIC that is reading a SQL table when an down time timer times out. The operator clicks on the popup, choose a button with...
3,348
This is the configuration: - MP277 10 Touch, configured with WinCC flexible 2008 SP1 HF2 - CPU S7-315 2DP - If I write in the DB of PLC "ABCDEFGH"...
2,153
I'm attempting to read some strings from a S7 300 PLC over ethernet. I'm using a IBH S7 Link mpi to ethernet converter and then use IBH OPC server...
6,424
