Real Time Clock in Schneider M340 PLC
Sep 2018
Chittorgarh
22
I have a system installed in my company which have M340 PLC and it has a program which is used toh turn lights on and off. I am attaching program pic for reference. Now I have to change on/off time can anyone tell me how the time conversion works here.
Here time reads with %SW51 and it is defined as int data type.
There are easier ways to do this with function blocks in the library. Attached is a picture of the different realt time clock function blocks
It can be configured to use a time server, but it only accepts IP addresses.
Because of this, I wrote a script in the hmi to update the plc clock.
RTC_Compare:= EQUAL_ARINT(Hours_6,Hour_memory_6);
(*EQUAL_ARINT(Hours_6,Hour_memory_6) > -1*)
IF (RTC_Compare > -1) THEN (*if time/date set words were changed, then set clock*)
SET(%S50);
%SW50 := INT_TO_BCD(Hours_6[2] * 100);(*seconds*)
%SW51 := INT_TO_BCD((Hours_6[0] * 100) + Hours_6[1]);(*hours and minutes*)
%SW52 := INT_TO_BCD((Hours_6[3] * 100) + Hours_6[4]);(*month and day*)
%SW53 := INT_TO_BCD(Hours_6[5]);(*year*)
ELSE (*if no change in set words, just update them to the clock values*)
(*display hh mm ss mm dd yyyy MW2161-MW2166 *)
Hours_6[0] := BCD_TO_INT(%SW51 / 256);(*hours*)
Hours_6[1] := BCD_TO_INT(%SW51 MOD 256);(*minutes*)
Hours_6[2] := BCD_TO_INT(%SW50 / 256);(*seconds*)
Hours_6[3] := BCD_TO_INT(%SW52 / 256);(*month*)
Hours_6[4] := BCD_TO_INT(%SW52 MOD 256);(*day*)
Hours_6[5] := BCD_TO_INT(%SW53);(*year*)
IF (%S50) THEN
RESET(%S50);
END_IF;
END_IF;
Hour_memory_6 := Hours_6 ;(*set memory words to detect any change next scan*)
Hello. This is one for the Mitsubishi experts. I need to measure the time for a remote device's to return process data sent from the i-QR...
17
2,136
Hi all I thought I had this working but upon doing a checkup a few months after the machine was commissioned, I found that adjusting the RTC via...
1,872
hi all i have used a real time clock to turn on a bit after 1 month. the plc was off for this whole month and when i turned on the plc after a...
1,422
hey, anyone know how to export time from panelview 800 to micro 850 and to compare time? or distinguish various time , like to know which shift...
1,461
Hi again Looking to write date or time values to the RTC in my MicroLogix 1400 In the ladder logic I am using a CPW instruction as per the 1400...
3,270
