Real Time Clock on Micro's
madohman
Jan 2007
Illinois
You guys were so quick to answer my last question, so here I am again.
Does a Micro 1000 have a real time clock? I don't think it does, but the maintenance guy does.
We want to be able to find out when the last time an input or output was used. Building a test fixture to test a door and if nobody is around, we want to know when the last date/time it cycled.
If anybody has a suggestions, please let me know.
If memory serves, It is an add on option. Most 1000's do NOT have it installed.
I am sure someone else will know for sure.
RSL
The MicroLogix 1000 has no real-time clock. All it has is a "free running clock", which is really only useful for comparing timestamps.
A real-time clock is built into the MicroLogix 1100, and is available as an add-on option module for the MicroLogix 1200 and 1500 controllers.
If you happen to have a PanelView attached to the controller, I think you can write the PV clock's time into controller registers and use that to record an event time.
I have used this method before, only down side is the clock is updated on a minute basis only
hey, anyone know how to export time from panelview 800 to micro 850 and to compare time? or distinguish various time , like to know which shift...
1,469
Hello. This is one for the Mitsubishi experts. I need to measure the time for a remote device's to return process data sent from the i-QR...
17
2,171
Hi all I thought I had this working but upon doing a checkup a few months after the machine was commissioned, I found that adjusting the RTC via...
1,880
hi all i have used a real time clock to turn on a bit after 1 month. the plc was off for this whole month and when i turned on the plc after a...
1,427
Hi again Looking to write date or time values to the RTC in my MicroLogix 1400 In the ladder logic I am using a CPW instruction as per the 1400...
3,294
