Real-Time Ethernet USB Adapter
vinny
Jun 2015
Brackley
Hi
I just given a swanky new laptop at work, which is lovely and everything, but does not have an ethernet port. Unfazed by this, I just got hold of a USB to LAN adapter and got to work.
My primary development environment is Beckhoff TwinCAT, and was rather gutted to find there are no real-time ethernet devices on the machine(attached image for reference).
I was wondering if there was any adapter that I could use for real-time ethernet device. I am aware of latency issues and this would only be used to test communication and make sure everything talk to each other.
Cheers
qecvvd9
How about carrying around a wifi router? Connect to it with your laptop & CAT5 (or CAT6) it to PLC or office network. That would give you better comm's speed than a USB adapter I think.
I would honestly tell them thanks for the laptop, but please return this hipster one and let me pick out something that will be useful to someone who wants to accomplish work with the laptop
Must the Ethernet connection be true realtime ? I dont think so.
I am guessing you want to connect to a controller where the Twincat PLC runtime is running.
If so, you are not online via Ethercat (realtime) but via regular TCP/IP (not realtime).
The issue is not the bandwidth but the adapter itself being compatible with the Twincat system. I was told it has to be an intel chipset but I have no idea of how to find an usb adapter which will take intel drivers
Even with PCI ethernet cards, Beckhoff originally required a particular Intel chipset to work with their "real-time ethernet" driver. But, in later years, they supported many more NIC cards. However, I think it is rare to need "RT ethernet" today. I only used it with the BK9000 coupler for K-bus modules, before EtherCAT launched. When you auto-configure a new PLC project today, it "finds" RT ethernet for your NIC card (if supported), but I just take the RT ethernet "device" out of my project. Perhaps there are some external boxes that still need it (motor controllers?).
BTW, a USB-ethernet adapter can be problematic in other ways. I used one in a PLC project long ago as a "regular LAN" interface (not RT ethernet) into a Beckhoff PLC (from my VB HMI program). But, it would periodically get lost (ex. after reboot), so the user had to unplug and replug the adapter to get the link working. Beckhoff later added more NIC ports to their CPU's so I no longer needed the USB adapter.
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
126
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
129
I am trying to copy an array of real numbers into a UDT with a real data type element. I have attached a snip below showing my COP instruction...
207
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
106
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,417
