Real time on Micro850
blackbird307
Jun 2015
Winnipeg
59
I need the program to execute certain operations at certain times of the day. However, I just discovered my Micro850 does not have a built in RTC. I have a panelview 800, I was wondering if I could use the time from that, and port it to the PLC. I am using workbench. Does anyone know if this is possible? If so how would I proceed on doing this?
Does anyone have an other solutions?
Thanks!
I tried using a numberic data entry, added $SysClockHour as the read tag, and then another tag to share between the PLC and HMI panelview, but all I see is 0 on the PLC, but 10 (10am) on the HMI screen.
I also tried setting the destination tag for the system variable to the one shared with HMI/PLC. It still didn't do anything.
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
125
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
123
I am trying to copy an array of real numbers into a UDT with a real data type element. I have attached a snip below showing my COP instruction...
204
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
104
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,409
