recieving ascii ch0 in a micro 1100
potch
Sep 2007
OHIO
Hello all! I have a micro 1100 and am trying to recieve a string from a cognex dataman barcode reader. I am not very familar with the ascii instructions and can't seem to recieve the string. Can anybody help?? Thanks
Cognex
Welcome to the forum.
You may get a quicker reply involving a cognex product over at mrplc.com.
Bob, Thanks for the suggestion. I don't think that the problem is with the dataman, I'm not real sure what the best instructions would be to use wether I should use ARD or the ARL. I'm not sure of the proper procedure for clearing the buffer either. The communications are setup for the same baud rate and parity. The string is 8 digits.
a little more info
My baud rates and parity are identical. If I hook the dataman up to my laptop in hyperterminal I can see the string. I am using the default termination characters in the plc which are \d for term 1 and \ff for term 2. My dataman I have setup to send the string and a carriage return. Not real sure this could be my problem. Have tried ard, arl, and test for string and nothing is found.
I am now recieving an (OEh) error on my ARD. Does anyone know what this error code is?? I couldn't find it when I tried to look it up.
From the help files...
0E The ACL instruction was aborted.No action required.
Rockwell Software 2000
I'm using ICX HWC35 cellular gateway with Allen Bradley 1769 L33ER PLC for messaging purpose Already upload the AOI instruction to the project...
4,400
Hi All, Has anyone worked o a project with a master plc and other remote plc that talk to each other using sms and or GPRS and sms as backup...
2,013
Hi, i don't know if this is a right place for this but does any one have an idea on how i can receive messages from a phone to a PC, send the data...
1,774
I need to grab data out of an array string for example, I'm reading in MYArray.ReadString[0], for example reading... MYArray.ReadString[0] *...
3,106
Hi, We couldn’t find anything specific, so am starting a new thread. I’m trying to migrate a config from a ML1400 to a micro820 & am experiencing...
94
