Recommend a PLC for a WELDER/PLASMA CUTTER
ichudov
May 2006
USA
I am messing with my welding machine -- former 3 phase Hobart CyberTig
-- by changing it to use a PCTI SCR firing controller. Without tiring
you guys with details, it will also have a switchable voltage range,
0-90VDC and 0-300VDC (the latter for plasma cutting).
I have gotten to the point where basic stick welding works fine.
Now I am facing a task of making a real control system for it. I could
do it with relays, but that is cumbersome and hard to reconfigure.
I am now considering some programmable control, since it makes making
changes considerably easier. I am a computer programmer, so I know
the basics of programming. I had some suggestions in the past that I
shoudl consider the microcontroller route, and now I agree.
It would be good to get something that could handle maybe a dozen
inputs, have a dozen or so outputs, and is programmable via serial
port.
Not sure what exactly I need, PLC or microcontroller or whatever, but
it needs to have relay outputs and discrete and non discrete inputs
and outputs.
I would greatly prefer something that can be i nterfaced to through
Linux, since that's what I have, but I could use Windows software
also.
I have 12VDC and 120 VAC power inside the welder.
Any suggestions? Used stuff is fine with me. I saw some Omron Sysmacs
sold on ebay for not too much, anyone knows if they are any good?
thank you!!!
Automation Direct has the DL06 with 20 inputs and 16 outputs which can work with 12vdc or 120vac. http://web4.automationdirect.com/adc/Shopping/Catalog/PLC_Hardware/DirectLogic_06/PLC_Units
It may be possible to use their free downloadable software for this project: http://web4.automationdirect.com/adc/Shopping/Catalog/PLC_Hardware/DirectLogic_06/Programming_SW_-a-_Cables/PC-DS100
You will have to use Windows but you can make a cable, the information for that is also on the site.
SINCE you stated you are a computer programmer I will assume you are familiar with C programming and want the ability to work in Linux then you may want to look at Rabbit microcontroller kits:
http://www.rabbitsemiconductor.com/products/kits/
I may be wrong about the C software running in Linux because I do not see a reference that states it now but I could have sworn it was an option.
I'm on the hunt for for a "Balance of Plant" PLC (or alternative) that is capable of exchanging (sending and receiving) a small number of bit...
2,184
Hi All, I'm looking for a PLC and HMI for a small brewery to monitor fermenter temperatures and adjust setpoints. The part I'm struggling with is...
3,580
I need to consolidate data from PLC's on two DH485 networks and serve them to a SCADA system over Ethernet for access using a Kepware OPC server...
2,997
We got 23 Batch mixer that can heat (with water, steam or oil) or be put in Cooling ( Water or Oil) and all the heat/cooling work with Pneumatic...
2,933
Hello all, love the forum. So, I'm not really a PLC programmer... I'm an EE with lots of experience with FPGAs and programming, but...
6,949
