Red Lion Crimson 3 emulator
frankv1
Nov 2013
Swieqi
Usual boring question by newbee;
Am trying to write and implement some simple programs with Crimson 3 software with a virtual setup of Modular controller CSMSTRGT and a few modules ( I/O , Analog IN etc) When i try to run the program using the emulator all i get is; "EMULATOR NOT SUPPORTED WITH THIS MODEL"
I have tried all combinations of settings on the Communications tab with no results.
Any help appreciated
Welcome to the forum.
Are you using a Kadet model? The emulator does not support Kadets.
If you want to try out code then change to a model that the emulator supports. After you work out the kinks then transfer it to a Kadet project.
Thanks for reply.
I have tried to find a list on the user manual of what the emulator supports but can not find one.
As per my original post i need to simulate a program using CSMSTRGT modular controller with some I/O modules.Would submit a working program on PC to client.On approval i can order hardware.
Hello,
I am sorry but the emulator doesn't support the Modular Controller. The only models supported are the color HMIs in the Kadet, G3, and Graphite Lines.
I tried to update the emulateur with my USB cable on the Master CSMSTRGT whos connected on a CSDIO14 and he says Emulator not supported with this model. I'm using Vista 32 bits. I'm new with all those plc things i'm an industriel engineer student and i have a project in a rebar factory. I want to know when a machine (SHEAR) is running and when it isnt. So when i arrive here the master and the csdio14 was already installed. Any tips will be appreciate.
thanks
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
128
Hi, I am trying to increase the size of the user login pop up using a Red Lion CR1000 7” HMI with Crimson 3.1 software. The login pop up is very...
693
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,142
Hi I have been using Red Lion products for some time, I had a thought over the bank holiday weekend, As you do. It would be nice if whenever a...
1,033
Well, I have yet another question for the great minds on this forum! We have a red lion HMI for one of our machines and every time I hook my...
1,702
