I think I found the source of the issue. So I've been playing around with it, and I realized that the 3.0 emulator is working, while the 3.2 is not working, with the exact same configuration.
I looked into the 3.0 emulator, and each time I loaded it, I noticed it was using a different port. First 34066, then 36133, then 37700.
However, when I use the 3.2 emulator, it always communicates on port 0.
I'm trying to communicate via modbus to a Triconex PLC. Unfortunately, triconex has a port restriction on ports below 1024.
Is there a way to change what port the 3.2 emulator uses?
Thanks!
