Red Lion Crimson Emulator
Steve Bailey
Apr 2002
The boondocks of Western Massachusetts USA
8,593
I have to make some changes to a system that uses a Red Lion controller to read data from several barcode scanners and pass that data to a PLC. I have a spare barcode scanner and PLC, but I don't have a spare Red Lion controller so I thought I'd try the emulator. When I run the emulator it can see the PLC bit that triggers the script I need to modify, but it doesn't appear that the script is actually executed. I went so far as to insert a line at the start of the script to write "Hello" to a string tag, but I don't see "Hello" as the value for the tag.
Does the emulator run scripts?
Steve it will run in the emulator. When I have issues with s script running I add a tag at the start of the program (START++) and another at then end (END++)
Everytime the script scans the START tag it will add 1 to the current value the same with END. So you shiuld se them increment. A simple tag on the screen will save you a bunch of time troubleshooting a problem that isn't a problem.
Jeff that is a great idea. I've never actually done it that way and I'm now kicking myself for how much time I've wasted in the past.
Steve,
Yes the crimson emulator runs scripts. In my experience, it should function exactly as a real world screen.
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
110
Hi, I am trying to increase the size of the user login pop up using a Red Lion CR1000 7” HMI with Crimson 3.1 software. The login pop up is very...
686
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,126
Hi I have been using Red Lion products for some time, I had a thought over the bank holiday weekend, As you do. It would be nice if whenever a...
1,024
Well, I have yet another question for the great minds on this forum! We have a red lion HMI for one of our machines and every time I hook my...
1,678
