Red Lion Crimson3 emulator
SaDupp
Jul 2014
Calgary
I tried to update the emulateur with my USB cable on the Master CSMSTRGT whos connected on a CSDIO14 and he says Emulator not supported with this model. I'm using Vista 32 bits. I'm new with all those plc things i'm an industriel engineer student and i have a project in a rebar factory. I want to know when a machine (SHEAR) is running and when it isnt. So when i arrive here the master and the csdio14 was already installed. Any tips will be appreciate.
thanks
If you are working with real hardware, then you do not want to download/update the emulator, for it exists only in your PC ram. And, I am not familiar with your hardware, perhaps it cannot be emulated?
Under Link, Options, You want to pick the USB cable after unticking the "Send to emulator" tickbox at the bottom.
Further research tells me that the Modular Controller is not supported in the emulator, so you will have to do your testing with the real controller. See above to set up the link options.
As for programming the unit, if you can post your work (zip it first) I am curious and others with experience using that series of controller will be able to help you succeed. Now what are you going to do with that true/false running status?
Thanks, My true/false running status is supposed to start a timer with my program
If Input1
timer1 = true
else
timer1 = false
i have 3 input( 2 conveyors and a shear)
and after ill try to get the excel file with my tags ValueTimer1,2,3
Its supposed to be simple but its the first time im using crimson so i read a lot of thread to learn about the software
Does anyone know how to create a link to excel using Crimson3 software? I have done this with RSLinx before and would like to monitor data from a...
2,709
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
63
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
275
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
287
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
121
