Brian@HCI
Hello all,
I tried searching the site for this topic but came up with nothing so here goes==>
What would be the BEST or easiest way to print a message to the Pop-Up screen DEPENDENT on an action in the tags or code?
For example - the error handler subroutine has to tell the user 1.) Which actuator has a problem and 2.) What problem we are dealing with and then 3.) Recommended actions. So as you can see the recommended actions are based on what the problem is and also which actuator we are talking about here.
Any suggestions how to do this?
Also, just on the off note, how do you Pre-define string arrays with predetermined text?
Brian
Brian
