Red Lion G310 Startup Issue
kbcombs
Apr 2005
Muncie, IN
47
I am having a problem with a Red Lion G310 operator interface unit. I have apparently downloaded something that it didn't care for. When I power-cycle the unit, it appears to start normally but it gets stuck on a screen that says "STARTING SYSTEM" and just hangs there. Unfortunatley, it is Saturday and I can't call their Tech Support. Anybody have any suggestions such as a factory reset or anything like that. Any suggestions appreciated. Thanks!
Thanks for the response, Stu. I had read the technote from Red Lion but that wasn't much help. I read thru the other thread you linked to and that gave me the idea to try to load a program into the G310 using Crimson2 instead of Crimson3. That worked! It loaded some older firmware (I think) and started working again. I then sent it what I needed in Crimson3 and it seems to have accepted it. Kind of annoying, but seems to be ok now. Thanks again for the response! I really appreciate it! Kyle.
If this happens again you can simply hold down the first two soft keys at power up and it will prompt you to clear the database.
Jeremy
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,138
Is it possible to print a file from a Red Lion G310 HMI to a networked printer over ethernet?
1,290
Hi. We are currently experiencing slow loading or response time on our Red Lion G310, at about 5-10 seconds delay once we press a button or even...
1,636
This is my first time using these two, and I have picked it up fairly well. I don't have much programming experience(very, very little), but I...
1,643
I currently have RS Logix set up with a ladder logic program, when I force inputs from RS Logix I can get it to update the Red Lion G310 HMI...
2,081
