Red Lion G310 with a bar code scanner
Randy Turner
Dec 2009
Montpelier, Ohio
21
I currently have a Red Lion G310 HMI and have a Unitech bar code scanner hooked to it through the USB host port B on the HMI. It works fine when touching a data entry cell to bring up the on screen keypad, then scanning a bar code into it. It populates the string tag with the correct data, and closes the data entry keypad on the screen. My issue is, I want to be able to scan product codes to a tag, and log them. This would require the tag to "always be live" to read the USB port when the operator scans the bar code with the trigger on the scanner. I don't want the operator to have to touch a data entry cell on the screen everytime, before scanning the code. Does anyone have any suggestions?
Thanks,
Randy
I don't think so. Currently the only thing you can do is keep opening the data input. I suggest you use a serial scanner and run a program in the background. It will make things a lot easier for you.
I was afraid of that. I saw where there were "port" functions that would allow me to monitor data coming in, but it appeared those were for the RS232/485 ports only.
Thanks for responding.
Randy
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,125
Is it possible to print a file from a Red Lion G310 HMI to a networked printer over ethernet?
1,285
Hi. We are currently experiencing slow loading or response time on our Red Lion G310, at about 5-10 seconds delay once we press a button or even...
1,624
This is my first time using these two, and I have picked it up fairly well. I don't have much programming experience(very, very little), but I...
1,634
I currently have RS Logix set up with a ladder logic program, when I force inputs from RS Logix I can get it to update the Red Lion G310 HMI...
2,064
