Red Lion G315 and DSPSX000 communication
amitpanvekar
Jan 2013
London
44
I got six RS232 stream form GPS receiver. I am connecting three RS232 to G315(which is the heart of entire system) and other three to DSPSX00.
How can I connect the DSPSX00 with G315 so that I can control the data received in DSPSX00 through G315 ? Is it possible to connect using Modbus TCP (G315 is master and DSPSX00 slave)?
Cheers
The best way to connect two red lion devices together is through Modbus TCP. Have one device as slave and the other as master.
Jeremy
Jeremy
Jeremy,
I have normally used Modbus TCP in this type of application but wouldn't enabling OPC Proxy (in the slave) be another option?
Then he could use the OPC TCP/IP Master on the Other device(s).
Jeremy,
Yes OPC is another option but in my opinion Modbus is the best option. The OPC method can become too slow in applications with large amounts of data.
Jeremy
Jeremy
Good information.
I think the OPC method is a good solution when you need to pass strings between the devices, though.
You are correct about the strings and in that case I often recommend using both OPC and Modbus. OPC just for the strings.
Many thanks JeremyH and JHarbin for your help.
I am passing string, integer and floating point information between devices. I have tried OPC and it is really slow. I will try the Modbus TCP.
Could you please tell how would I connect G315,DSPSX and CSMSTRX using ntron 104TX and transfer data between all these devices ?
Cheers
I have tried the Modbus TCP/IP Protocol, it is faster than OPC but the problem I am experiencing that I couldn't able to use string tags to holding registers.
Any suggestions ?
Your help is appreciated.
Cheers
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
58
The HMI is a re-branded Red Lion G315 (Eurotherm). The project is adding a small, inexpensive PLC, with a handful of discrete IO, and 2, 4-20 mA...
6,067
I have not been able to get the elapsed time from a timer in a Siemens Simatic S7-1200 to display correctly on a Red Lion G315 HMI. I have...
18
8,585
I'm trying to send a new file to a G315 panel and I am getting ERROR: Memory Card is required for this operation. I have never seen this before...
2,038
Hello All, Thanks in advance for any help you can provide. I have a G315 HMI that I am trying to configure to send mail on alarms, but have not...
6,219
