Cnorez
Hi, i am having an issue with a RedLion G303 when i manually assign an IP/subnet to the ethernet interface. If i manually set up the G303 with address of 199.3.2.12 subnet of 255.255.255.0 and set my PC manually to 199.3.2.3 subnet 255.255.255.0 i can not ping the G303. nor does it talk to the other devices on the network. But when i set up the G303 to obtain it's address via DHCP it will recieve an address of 199.3.2.100 subnet 255.255.255.0 and i am able to ping the G303 with my PC still set manually to 199.3.2.3 subnet 255.255.255.0 and the G303 communicates with the other devices on the network. I have double checked that the 199.3.2.12 address is not assigned to another device. I have tried putting just my PC and the G303 on a switch by them selves and tried a crossover cable with the G303 plunged directly in to my PC. I have had no luck getting the G303 to communicate with a manualy set IP address and subnet. Anyone have any suggestions?
Thanks in advance.
Chris
Thanks in advance.
Chris
