RedLion G306/G310 - not serving web pages
AdrianEL
Nov 2013
Edinburgh
33
Hi all
I just upgraded our G306 to a bigger G310 display. The G310 just will not serve a web page to the Internet. I can see it on the LAN perfectly well and the port forwarding is set up on the router. Basically everything is the same as the previous G306 which worked fine. I have compared all the settings in both devices and they are identical (at least as far as IP, web server, etc ) although of course the database is different.
I know the router settings inside out - I have done this hundreds of times and it works. But I just can't get the G310 to serve pages outside the LAN
Any ideas?
Hi all
Any ideas?
If you are using the same IP address, it may take the router to recognize the new MAC as the destination.
I'd be interested to see if it works tomorrow morning. If not, post the two databases and let us take a look at them.
Thanks for looking
I found that if I set the DNS servers manually the G310 works as expected. Odd because the previous G306 definately did not have these set manually. So somehow the DHCP system was not communicating the DNS server info to the G3.
Hi, I have a Redlion G306 and its GSM Modem add on which I have successfully managed to send and receive texts from. I'm interested to know...
2,172
Hello masters, I have a trouble, I need change the IP for ML1400, I have a program with download the results with archive csv, but the program it...
2,960
I have a G306 hmi I have tried to upgrade from a panelview 600 on an existing line that is connected to a SLC 5/03. I have had succuess for the...
2,589
HI, As you can see from my name ! I am struggling ! I am trying to get my SLC 5/03 talking to and working with my RED LION G306 Hmi. I have...
4,298
Is there a way to have an Allen-Bradley Micrologix 1100 control the screen changes in a Redlion G306? I can't seem to find any way to associate...
2,794
