Redlion meter to control a pump motor
irondesk40
Jan 2008
nc
630
Had a vendor that builds pump control stations tell me that you could use a Red Lion cub type meter to control the speed of a chemical injection pump instead of a plc.
Is it possible to control the speed of pump motor that for example runs from 0-1750 rpm and this is equal to a flow of 0-3 gallons per minute and have a mag type flow meter as feed back into the Red Lion meter to maintain the desired setpoint?
1. Operator would select to run 2 gpm
2. Pump drive would turn on and a analog output from the Red Lion meter
would command the Pump to run at the desired RPM to match 2gpm.
3. Flow meter be inline to sense the actual flow of Liquid and be used as a
feedback to the Red Lion meter and a PID loop within the Red Lion meter
work to maintain the actual set point based on the flow meter input.
Have done this many times using a Allen Bradley PLC, but never thought about just using a Red Lion Cub type panel meter.
Has anyone ever done this that might be willing to share and info or the
experience as far as how accurate it would maintain based on the setpoint.
That depends what is meant by "cub type". The Cub 5 or other with analog in & out then sure. Call Red Lion and ask for minimum meter needed, they are very responsive.
Hi, We are trying to use a PaxI meter with Profibus card for displaying values sent by a Siemens PLC, but PLC programmer is facing problem -...
2,101
Since the most recent Crimson update of C32-Gold-1016 I seem to have lost the ability to move files on the SD card. I run a background program...
50
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
156
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
195
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
246
