murarisetty_apparao
Hello,
We are using a DSP-LE000 REDLION Protocol Converter in one of our client premises to communicate between the AB PLC SLC5/03 & Siemens WINCC SCADA . The Input for DSP-LE000 unit is AB PLC SLC 5/03 DH485 network. The Output side is Ethernet connection to Siemens “WINCC” SCADA package. The configuration package for DSP-LE000 is Crimson 2.0 software. I am using this Protocol Converter first time….
Is there anybody to sortout my queries....
My Queries are as follows:
- In RS-485 port side I had selected the “Allen Bradley DH-485 Master”. In this Protocol Do I need to add the “Gateway Block”? & Why we need to add these blocks?
- In Ethernet port side, I had selected the “Siemens S7-300/400 TCP/IP Master” for WINCC Communication. In this Protocol what setting needs to be configured? Do I need to add the “Gateway Blocks” here also? Are these gateways blocks need to match with input side Gateway Blocks?
- In Siemens WINCC SCADA PC, What protocol needs to select in my project in the “Simatic S7 Protocol Suite” for getting the data of AB SLC 5/03 PLC?
