Redlion G3 - DNP Protocol
Marc_U
Sep 2006
Cumbria
193
Is there a DNP3 protocol driver available for the Red-Lion G3 HMIs?
On either the Crimson 2 or Crimson 3 software?
It is still on the wish list, but it is being actively investigated. Part of that investigation is what level is required by our users. What DNP level (forgive me if that terminology is messed up) would be required by your applications?
Regards,
Dan
I mainly use the G3 for protocol conversion so I have a standardized way to connect to the machine PLC from MES/shopfloor systems. Now I’m using modbus to read/write to holding registers, only 16bit int and float are possible. Using DNP3 will allow us to read/write events, 32bit int/float, strings and date/time. It will also reduce the network traffic because DNP3 is event based, the master will only report changes to the clients.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
226
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
661
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
829
