RedLion Raw RS-232 Serial Input
Lonestar71
Dec 2019
Houston
Good morning and new to the forum.
Attempting to configure a RedLion CU30D using it's RS-232 port to log the input stream. "Raw" ASCII data is considered a third party device?? Per RedLion, this requires a separate program that acts as a receive routine?
Has anyone ran into this?
Many thanks!🍻
Welcome to the PLCTalk forum community !
Please describe your device in more detail and your application in more context.
In general, you'll need to set up the serial port for "Raw Serial" mode as a Master, and call a Program on the OnUpdate() event.
That Program is what will read the buffers (PortRead and PortWrite and inByte instructions), process the strings, manipulate tags, and all that good stuff.
I don't have a general purpose example of "read the port and log the data" but there are some expert Red Lion folks here who can point you in the right direction.
Hello, I man trying to use a redlion DA10 converter to read data from a Bronkhorst mini cori flow meter over rs232. I cant seem to get the...
1,545
Working on a project where I need to set the voltage, current and read the status on some power supply's. There are 5 power supply's. Each has a...
3,135
Some questions on raw port usage on a Redlion G3, specifically UDP. I am trying to read arbitrary bytes from a UDP stream with Ethernet but I...
4,431
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
172
