Redundent wincc+client+OPC XML DA??
naishadgosai
Aug 2005
surat,gujarat
39
Dear All,
My config as follows.
- 1 pair of Redundent WinCC
- 1 WinCC Client
- OPC XML DA installed on client
- MES will access Wincc Data over OPC XML DA.
Q:
- how / can MES access historic data of WinCC( tag logging data)??
- Whatever tags MES accessing, it must be on Wincc client / can be on wincc server ( because normally all tags will be on server)??
- as per the attached picture, any explanation is available for the mentioned services....especially for get properties??
Hello, I am trying to connect kepServerEx v5 in parallel with RSLinx Classic lite but kepserver will not connect to the PLC if RSLinx is active...
2,112
Dear all i oome to find that my master cpu all leds is flashing and as per manual this means that CPU is faulty so can u advise, is it...
2,357
dear all experts one day i found that the master cpu's all leds is flashing and control transfered to the slave one after trouble shooting the...
3,085
i have two plc slc5-05 1747-L553 and 1747-bsn backup scanner my quastion , how i can transfer data table between two plc ?
1,440
Hi everyone, I have an issue, how is it possible to read data from an XML file with Delta PLC? In fact, I have another device (ElectroCell from...
1,148
