The Process Variable (the parameter that is being controlled) would be the temperature inside the refrigerator. Normally, most refrigeration systems use ON/OFF control where the compressor is either running or not, but a larger refrigeration system could also be controlled by compressor speed, by number of compressors running, or by a variable compressor unloader valve.
