Related to Omron PLC CP1H series
ameyapte
Jun 2010
pune
Dear friends i m using CP1H series OMRON plc and Cx-programmer software for same plc. I want to use Decrement instruction for the same. I tried it but i m not getting the correct result.
Actually i m entering the decimal value from HMI in to one register.That register i want to decreament that register value by 1 on 2 sec pulse. So when i wrote 1300 decimal into one register from HMI , then upto 1280 it will decreament the register value by 1 correctly. But after that it will directly decreament to 1187. And i want the value in rgister should be in decimal only.
May be this problem is because of BCD decrment instruction.
So please give me the solution regarding problem.
Thanks & Regards:.
AMEY APTE
PUNE
Pay attention you need to be same format on the HMI and the PLC.
BCD or Decimal.
Also make sure you put @INC and not Just INC.
regarding OMRON PLC decrment register value
dear firends
I m using @--B (dereament) instruction for decreament the value for OMRON CP1H-40xDR-A series plc.
I m using NP5-00B series HMI. I m entering value 1300 from HMI into D711 register in decimal format. So when i saw into program i can see it into decimal value at D711. But when i m doing execution of instruction it will decreament it upto 1280 correctly by 1. But after that value it will show me the result 1177 . So can you help me regarding this.As i want that register value only in decimal.
Also i same tried with substraction instruction but the result is same..
PLZ help me/....
Hmmm
This is too much like the post by CLXenggr, except you have not mentioned the PLC model.
If you (or CLXenggr) posts a copy of your code, then we can have a look to see what is going on. o_O
I have to ask, why are you using BCD? I have not used the NP5, does this only support BCD??
Dear friend
NP5 series HMI also supports all BCD,DECIMAL,HEX value support. But i think main problem is with PLC instruction, as which PLC model m using is having only BCD and BINARY supprots instruction...
I m entering the value from HMI is DECIMAL ..
But the instruction in PLC is "@--B" (decreament register value by 1). THIS instruction is BCD decreament
. But i want decimal decrement.
So how can i solve this...
You are right Mr LostControl,
My friend Amey is on the project and I was away on a site so two posts. Well, the problem is solved now . It was problem of representation in hex, octal and decimal.
Thanks.
clxenggr
We got one installation that have most of the Win10 PC in a rack above the control room. In the past they always used various flavor of KVM...
2,990
I need to know how to take a schematic like this and solve it for let’s say a run time of 5 seconds By solve I mean determine which rungs are...
33
9,180
What's your favourite source of PLC/SCADA-related news? Maybe some of you still read printed magazines?
2,088
... yesterday I removed the plastic liner on the tail-gate of my Kia Soul to get at the broken reversing camera... It has 12 of those plastic...
17
7,268
Good morning all, this is not PLC related so if not allowed just delete. But i have a problem with my RV that has got me stumped big time. I have...
3,718
