Relay Chatter
Relay Chatter is fixed I think
I have not seen any relay chatter or motor overload trips since I replaced the processor with the saved logic yesterday afternoon.
I have been sitting in this room for 4 hour today and everything looks OK.
I guessing that it either had to be corrupted code or a bit the processor felt like pulsing.
Hopefully I'll get the time to download the saved program into the processor that was in durning the chattering and see which item was the issue.
This is a very helpful web site even more so since I'm the only "PLC/Electrical Control/Scada/System designer/etc." person at my plant. Sometimes it just good to have someone that speaks my language
Again thanks for all the help and the suggestions. It's great to know that I have so much support.
MRDEGOLD
beerchug
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
118
Hello, I need assistance in making a Relay operation that follows the given parameters: -if S1 is switched and S2 is at off, the Lamp 1 will be...
116
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
444
I have an application where I want to use a safety relay in combination with a flame detector as the sensing element. The flame detector has relay...
23
1,094
