I have a relay output card that keeps having issues but with different relays. Every couple of weeks or so, an output relay will energize but will not de-energize. I'm not really given enough time to troubleshoot the machine so I just put another module in to keep it running for a few more weeks until the issue inevitably happens again. The OTE in the program shows that it should not be energized but it is. The output terminal shows 24VDC and that reading never goes to zero when the output signal should be off. I checked the incoming voltage and its around 24vdc. All of the connections are tight as well. Does anyone have any advice for me on why the relays keep failing? Thanks.
