Relay question
m_paper
Aug 2017
winchester
Hi all I have a relay question, we are currently using Allen Bradley tamper proof relays. Two wired in series one set of contacts is used a plc safety input the other set is used for the dc output bus on the plc. My question is with the contractor/relay being in a dusty environment is it possible to replace the relays with an ice cube style relay or will that change the classification of the safety system?
Welcome to the forum!
By that do you mean solely the bus plane power for the IO modules, or is it actually giving the field supply to the outputs themselves?
Thank you for your input. I was afraid of that perhaps a positive pressure to the cabinet would be a better solution. Those type of contractor relays do not handle dust very will even though it’s limited amount of dust it’s always been a problem. Thanks again
Bath and kitchen converting (paper towels and toilet paper) a lot of dust. The cabinets are fairly well sealed but the dust manages to find away in
This sounds like it's a safety relay if so it must be replaced with another safety relay
those are Forced Guided Contacts
You may try to place the relay inside a NEMA 4 enclosure to protect it.
Can we get a part number for the relay? A lot of times you can find a product that is very similar but rated for that environment. We had some issues with an AB safety relay and swapped it out for an Omron one in most of our controllers. They only last a little longer, but they are less than half the price. Perhaps you would be able to do the same.
As a side note, and by design, those safety relays are finicky.
I need a double-pole single-throw relay in my application. I simply need two sets of N.O. contacts that close when the coil is energized. Nothing...
772
We have a line of equipment where half of it is controlled from one control panel and half from a second control panel. We will have an e-stop in...
2,239
I have a Omron G9SA-301 safety Relay and it has a port for what looks like programming. I can't find any information on it or an associated cable...
1,499
Hello, I have a question about a product in general. I'm looking at a Carbon Monoxide detector product datasheet. In it it says that is has...
4,238
Can anyone please explain me what is lockout condition for Allen Bradley Safety relay MSR138DP.Why or what reason lockout condition happens and...
2,476
