Elementary Relay Question
eaglewood
Supporting Member
Jan 2022
Reno, Nevada
36
I need a double-pole single-throw relay in my application. I simply need two sets of N.O. contacts that close when the coil is energized. Nothing else. When the coil is not energized, I want no circuit energized.
When I go to purchase a DPST relay, I find them relatively unavailable, as opposed to DPTD relays, which are far more common.
I don't see any harm in using a DPDT, it's just that the power voltage will be present at the unused contacts.
No big deal, I'm just curious why DPST seem to be relatively scarce. And I also thought I'd make sure I'm not missing something. Like... NOOOOOO for god's sake don't use a DPDT when you really need a DPST!
That's funny, I went to RS Components & the first page showed 9 of them there were over 70 pages although many may not be suitable surely there are a vast array of DPST.
I think you're probably overthinking it too (hey, no judgement...I do too)...but if you're worried about the power voltage being on "extra" terminals when the relay is de-energized, you can wire the power to the NO contact and the load to the common.
What about supplying power to the N.O. contact? When that relay coil is not energized power is not available on the common or N.C. contact. The N.O. contact still acts as a switch with load carrying capability?
Hi, So, I eventually got a zelio to work with. 2 silly questions: Do I need a manual push button as an input to the smart relay to make it start...
2,724
Hi All, Finally getting through the SLC brick project on the G304K- kudos to Red Lion for the fix, it does communicate with the brick!:beerchug...
2,517
Hi there! Want to do one elementary operation with KTP400. I have one boolean tag in PLC and want to set it then I push the functional key F1 of...
3,845
Hi all, Please refer to attached pdf. If a go with the second 2 disc configuration and apply the same clamping force as the original single...
2,988
Schneider Modicon Concept 2.5 Elementary Question Question - How do I copy the running Schneider Modicon Concept version 2.5 PLC program project...
7,897
