Schneider Modicon Concept 2.5 Elementary Question
mbd0722
Aug 2003
Taunton, MA
Question - How do I copy the running Schneider Modicon Concept version 2.5 PLC program project that is located on an Operators Workstation to an off-line location for storage. Do I need to copy the entire directory folder(s) or the .PRJ project file only?
Equipment: Quantum Series Redundant PLCs, IBM 7581 Operators Workstation computers
Software: Concept 2.5 SR2, GE Proficy HMI/SCADA iFix HMI, MS Windows NT4
Thank You
Assuming the project is named xyz, you'll want all of the files named xyz.* (xyz.prj, xyz.p1, etc) along with the directory named DFB (if there is one). If the project isn't stored in the Concept directory you'll also want the DFB subdirectory from the Concept directory.
You could also use the Concept Converter program and select "Export Project with used DFB's" to get a single file export of what you need.
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
239
Hey all, I do not have the original source code of a Modicon M172 PLC (HVAC PLC). I want to modify some of the code but read you cant upload...
343
Hi, I have an older Kohler Generator/ATS controller that has a Schneider Electric (Modicon) Momentum PLC and has a Advantech HMI. I assume this...
712
Hello, I'm having a hard time understanding how to get a Modicon M340 to pull a Modbus address from an ABB Totalflow via Ethernet. I set up a port...
1,155
