OT: Elementary force upon a brake disc question
HJTRBO
Jul 2008
Melbourne
618
Hi all,
Please refer to attached pdf.
If a go with the second 2 disc configuration and apply the same clamping force as the original single disc setup will that improve the braking power?
I appreciate any assistance greatfully.
Hmmm, sounds like a home work question!
Just to clear up, i'm an A grade Victorian sparky employed fulltime and NOT studying a course of any description...
Yes, it will be close to double the braking force with the same clamping force, if one or more of the disks can move axially (the center pad also needs to "float"). The overall thermal rating will not be doubled however.
Edit: Stearns, Nexen caliper?
Milldrone, thankyou for your reply. Caliper... Ah, Tamiya nitromethane R/C car. Now I have an hour or two on the lathe to spin up some new parts.(y)
I need a double-pole single-throw relay in my application. I simply need two sets of N.O. contacts that close when the coil is energized. Nothing...
770
Hi, So, I eventually got a zelio to work with. 2 silly questions: Do I need a manual push button as an input to the smart relay to make it start...
2,727
Hi All, Finally getting through the SLC brick project on the G304K- kudos to Red Lion for the fix, it does communicate with the brick!:beerchug...
2,520
Hi there! Want to do one elementary operation with KTP400. I have one boolean tag in PLC and want to set it then I push the functional key F1 of...
3,847
Schneider Modicon Concept 2.5 Elementary Question Question - How do I copy the running Schneider Modicon Concept version 2.5 PLC program project...
7,900
