Crimson 3.0 elementary question
tommy23t
Nov 2003
New Jersey
136
Hi All,
Finally getting through the SLC brick project on the G304K- kudos to Red Lion for the fix, it does communicate with the brick!🍻
My problem is that I cannot seem to find how to input a specific bit for a pushbutton. My timers work fine, I can change presets, but trying to use a screen pushbutton does not seem to work.
The problem is that the A/B uses bit level, the Red Lion word level. If I define the button as B11/17, which is B11/1.1, the Crimsom only gives me "word as word" in the B field- not able to get down to the single bit. I assume this would make the entire word true-if I choose B11:1.
I found at the end of the manual a reference to try:
CHANGING BIT VALUES
To change a bit within a tag, use the syntax Data.Bit=1 or Data.Bit=0 to set or clear the bit as required, where Data is the tag in question and Bit is the zero-based bit number. Note again that the value on the right-hand side of the = operator can be an expression if desired, such that an example such as Data.1=(Level>10) can be used to set or clear a bit depending on whether or not a tank level exceeds a preset value.
I tried entering my tag "man1.1=1" in the general data field, it did not like that. (man1 was defined in the tag as B11:0001)
Hopefully, I am overlooking the obvious, any help or suggestions are appreciated.
Thanks,
tommy23t
This gets everybody at first.
Make sure you choose a Flag tag type for a bit address. Then, on the tag screen, Data Source tab, you have the word level as the source, "B011:0001" then below that you have Extent "One Item", then Treat As "Bit Array Little Endian" and below that is where you choose the bit number "1" in your case.
Hey OkiePC!! (y)
Thanks so much, never would have stumbled upon that and still had all my hair!!
Have a great weekend, you made mine. :D
Thanks again
tommyt
I have been burnt by that one as well.
I bet Paul got burnt also. You get use to it being easy and then change to a new platform.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
230
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
108
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
96
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
91
