Rename DB180 in siemens to DB120
You can do it if you use a DB_NO type parameter in your function calls (which means you have planned for this beforehand).
If not, you have to go to each instance and change the DB number by hand.
Hope this helps,
Daniel Chartier
Hello, I'm working on a project using an Allen-Bradley 1769-L30ER v31 and a Panelveiw Plus7 v11. I have an AOI that keeps track of the time a...
167
I am trying to rename an AOI Definition and I keep getting the Error "Failed to Modify the instruction. Already Exists" But there isn't another...
2,695
Hey everyone, I did a bit of looking around this site and couldnt find any info for this issue. I havent worked with FTV too much but got a WO to...
1,562
Hello, it is possible to rename d.input or output in order to this change apply to whole project? I can change name easily in HW config of inputs...
1,455
Hi all, Working on an FTView SE application where I've been given a "sample" application to model the new one on. I've restored the APA using the...
10,401
