repairing a plc
basharath
Mar 2010
hyderabad
103
Dear all,my ge fanuc micro plc is not powering up,is it possible to repair the plc by replacing the burnt components.do any body know how to repair it..
thanks in advance.
i heard about some shop that repair and most of the time reconditionne plc stuff but i never used them.
In your case, to my opinon it will be cheaper to buy a new one
the board inside is probably double sided copper and surface mount so someone with usual solder iron and multimeter won't be able to figure it out if itsn't just a connection lousen problem....
Contact your local GE Fanuc rep. I haven't dealt with GE in awhile but I know they used to have a refurbish system. Basically you exchange your PLC for another one that has been repaired. Generally this is less expensive than buying a new one.
Check near the power input for a fuse. Check diodes or bridge. Replace capacitors with low ESR types, preferably Panasonic FC series.
I have been working for my employer for almost two years now. Getting into PLC's right after high school makes me still relatively new to this...
28
11,106
I am having some issues with a standalone WW Intouch app faulting during startup (Intouch 10.5). I am aware of how to completely rebuild the...
3,974
Any experience repairing or replacing a bad output relay?
3,861
As you probably now Rockwell will no longer support 1394GMC drives in the future. The series C has the state "Silver series" now. Are there any...
2,161
We have several Panal View 550s and the screens are getting very foggy and hard to read from glare from the shop lights. Is there a way to repair...
2,447
