Replace functionality of TSXCUSBMBP modbus +
harryting
May 2002
Puget Sound
2,595
I'm quite sure this usb modbus converter is toast. While trying to get a hold of another one, I wonder if there's any better option out there.
Background:
It's a USB to serial Modbus converter from Schneider. Documentation is hard to come by on it online. So what this box does, as far as I can tell is talk to a 485 network of modbus devices, both modbus plus and modbus RTU. It also have virtual serial port ability.
Kepware OPC then read it and connects with FTView SE. I am wondering if I'm missing something, because in my mind, why can't I just use a standard USB/485 adopter and use Kepware OPC modbus suite? Is there some functionality that I'm missing with TSXCUSBMBP?
An old thread on Control.com claims that Modbus Plus can run on 'regular' RS-485. I don't know the validity of that assertion, but it's here:
966282131
http://control.com/thread/966282131
Great link, thanks. I will read up on it.
It's the first time I encountered Modbus+ and I made some assumption that may not be true since I just assumed it to be RS485 but the taps they used here seems to be different than standard 485 wiring.
for now it seems I have no choice but to get one here. Longer term, we might see if it's worthwhile to eliminate this hard to get black-box.
We have a Beckhoff CP6201 PC and an EK1100 module communicating with it via EtherCAT in one of our machines. Due to problems with the PC, I want...
75
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,259
I’ve got some devices that are triggered by shorting pins to common. There is 24 volts on each pin and right now I am using a relay output card...
2,576
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,506
How can I achieve the same functionality in Studio 5000? Image 001.png for the old RSLogix500 program Image 002.png for conversion to Studio...
2,521
