Replace TP270 on MP270
Hi nguyenkuong.
You cannot directly take the runtime file from the TP270 and download it to the MP270.
It has to be converted to the MP270, and for this you need the original Protool or WinCC Flex project file.
There is a slim chance that there is a backup of the project file on the panel. In that case there must be a CompactFlash card in the slot in the rear of the panel. If there is, you can try to use the Upload function in Protool or WinCC Flexible (not Prosave).
That said, most programmers dont use the ability to store a backup of the project on the panel.
We have a Beckhoff CP6201 PC and an EK1100 module communicating with it via EtherCAT in one of our machines. Due to problems with the PC, I want...
77
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,269
I’ve got some devices that are triggered by shorting pins to common. There is 24 volts on each pin and right now I am using a relay output card...
2,598
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,515
How can I achieve the same functionality in Studio 5000? Image 001.png for the old RSLogix500 program Image 002.png for conversion to Studio...
2,547
