Replacement Servo Settings
Dryhops
Jan 2018
California
90
We had a servo fail and we are installing a slightly different model as a replacement.
When I update the motor catalog number in the axis properties menu, it understandably clears a few settings.
In the attached screenshots, the old motor has a rotary transmission with a ratio of 21:1. This simply corresponds to the ratio of the attached gearbox, correct? So I should reapply this setting to the new motor?
attachment.php
attachment.php
Also in the screenshots, the load ratio reset from 2.3 to zero. The load ratio is used to calculate the System Inertia (in the same window) - so should I back calculate the load ratio required to maintain the same system inertia? Or simply keep the 2.3 ?
attachment.php
attachment.php
Thanks for your time.
Hi : A customer have a servo motor MPM 3203R-1170, this motor was driven by a MPA-75-460, both unit were manufactured by MTS. Parker Hannifin...
3,632
Dear All, I've got assignment from my boss that ask me to replace obsolete model servo amp MR-J2 with new version of servo amp MR-J4. Actually...
5,323
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
146
Hi , I am trying to replace an old inverter with a new one and its giving me issues . Once the new one was installed , the S7-300 PLC started...
134
Hi Everyone, I replaced encoder 842D-60131331BXA with a new same part number. Dip switches and Preset Push button are considered. When I tested...
240
