reset a CTU counter
batindeko
Nov 2017
stutensee
Hi all, I'm newbie here to plctalk!
I writing a PLC programm in ladder where I put an output bit to zero during 9s and the same output bit to one during 1s. In the same time I count every pulse until 50 after that value the counter should be reset and stops to count. In my case this never happen in the next scan the counter keeps counting. I don't know how fix this issue or may be there another to do this.
find attach a picture of my ladder programm
thank for every contribution
Olivier
Welcome to the Forum
In order to receive a good response to your question, you will need to provide more information about the programming platform you are using. RSLogix, Siemens, Mitsubishi. ect.
Good luck!!
In the CTU line, try to put a "Not Done" as a pre-requisite of the counter.
CTU.DN Latch_M Counter_Block
---|/|------|/|------------------|CTU|--|
CTU.DN Latch_M
---| |---------------------------(L)--|
CTU.DN
--| |-------------------|MOV 0 -> CTU.Acc|--|
Have you tried something like this?
**This will make stop counting**
Then You can Latch a memory, and block the line, at the same time that you reset the counter.
CTU.DN Latch_M
CTU.DN
what do you mean here by latch your memory? I do not really understand which memory
SET / Reset memory
Usually ---(S) / ---(R)
But in the Logix 5000 it is "(L)" and "(U)".
(L) = When Latched, stays in state "1" until it receives a "(U)" Unlatch
I haven't come across this before. I am trying to understand why the counter doesn't reset to 0, when the .dn is true? It immediately puts a 1 in...
18
4,603
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
311
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
75
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
81
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
111
