Reset HSC in S7-1200
Ashwini Sahoo
Nov 2012
Faridabad
33
I am using HSC_1 in S7-1200,Encoder has PPR 1000.
In properties using external Reset option I can reset the HSC at 1000.
But unable to reset at any other values. For example what to do if I want to reset the counter at 500.
Plz Suggest any solution.
From what I understood on reading the manual,you can reset at other values by using comparison instruction on the directly read Count Value and setting CV = 1(keeping NEW_CV value as 0) when the desired current count value occurs, but it will not be very reliable because of the reason given in this note provided in the manual:
Hi. So I finally got my HSC to work with the RA_HSCPlugin thanks to @PLC Pie Guy . I'm using an AB 2080-LC20-20QWB with a 2080-MOT-HSC extension...
1,838
Have some project that we used the micrologix 1400 and a encoder to measure the rate in feet per minute and yards per minute. In the 1400 program...
2,270
Hi I use hsc in cp1e .i set hsc5 in setting and see the value in a324 and i set the type to software reset but i can not reset the value pleasehelp
1,423
Here is my dilemna. I have a 1756 HSC with 1000ppr encoders on each channel. I am using them for positional control on a carriage driven by a...
3,276
Hello friends, I am using Omron CP1E-N60DT1-D PLC with Pepperl Fuchs tvi50n rotary encoder 1000ppr. In CX-programmer 9.03 i have made following...
2,733
